Doesn’t start unless I prime with gas/starting fluid
Call Her Bu
111
38
Arlington, TX
I have a 78 Malibu with a 305 all original. It has the stock Rochester 2 barrel carb. Every morning I try to start it. I have to put gas or starting fluid in the carb to get it started. After it starts the car is fine. When I go somewhere, turn off the car and turn it back on it’s fine. It’s only when it’ss cold start. It also bogs down when I step on the gas. The carb was rebuilt also. I’ve put 91 fuel and Berryman fuel injector cleaner as well. Any suggestions or tips?
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
fuel pump is weak, putting gas down the carb to start it helps the pump by pulling the fuel
  • Love
Reactions: 4 users
lilbowtie
3,460
3,965
Canton Mi
Check in the morning if your getting fuel to the squirts which sounds like your not. If that's the case it sounds like your acceleration pump isn't working - bogging kinda backs that up. Next question would be if you have fuel enough pressure to the carb. Then I would question the carb rebuild and settings.
  • Winner
Reactions: 4 users
Call Her Bu
111
38
Arlington, TX
I will check in the morning to see if gas is spraying from the Jets. Thank you.
Call Her Bu
111
38
Arlington, TX
Ok so I have fuel going all the way to the fuel filter and no gas spraying out of the Jets. I’m gonna replace the fuel filter tomorrow. It looked pretty dirty.
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
fuel filter could be backwards, it takes lots of dirt to plug a filter
565bbchevy
9,633
12,760
Michigan
Didn't some of the stock carbs have well plugs that would sometimes leak the fuel into the intake?
MrSony
6,854
6,793
Des Moines, Iowa
That wouldn't cause a starting issue this uh, frequent. When that does happen it will start and run once the bowls fill back up. My bet is filter was installed wrong or pump took a dump.
