Forum advice for my car
Oct 14, 2008
8,843
7,810
Melville,Saskatchewan
Specs on the 350 will tell us what it puts out. Actually 400 HP is extremely easy to make, mine will be there with a head swap and install my mild roller cam. Even 450 HP is the old 350 HP for these motors, just not cheap. Talking 9.6 to 1 with a modern 1mm ring pack, aluminum heads and decent sized roller cam. Actually rogue_ryder just did one with the same bottom end as me, bigger roller cam and 64cc Procomp heads, just under 450 HP, like 437 HP. The new Edelbrock heads released next month would have tipped him over. I broke a No Slip on the 7.5" on slicks and exploded stock spider gears on the street. What other parts do you have in 7.5". You need Moser 28 spline axles, a strong posi and girdle cover to have any hope to survive. Good luck, you will need it.
DROLDS84
464
788
Northern Indiana
Come and get it!
UC645
1,119
3,284
Kittanning, Pa
If you want to keep it a cruiser that occasionally sees track time, go with a bolt in axle like the 8.5.
But for the same price, you could snag a Foxbody or early SN95 8.8 with adjustable control arms. Only major snags with that set up are wheels, the rear sway bar, and the control arms you can buy come with solid rod ends.
Wheels will need an inch or so more backspacing, as those 8.8s are 7/8ths of an inch wider per side.
