Head install help
purple78monte
14
2
so I’m running head studs on the 355 in my 78 Monte I ordered bolts originally and they sent me these instead figured they would be fine what I didn’t think of was with these would I run into issues with getting the head on between the ac box and the studs and as you guys could guess I did so my question is what do I do from here I’ve already got the drivers side done and torqued down with the studs could I take the studs out on the passenger side and just run head bolts on that side or would that be a bad idea with the studs already in use on the other side
Ribbedroof
4,942
7,097
Wellston, OK
Pull offending studs, install head on dowels, reinstall studs, add washers and nuts... done
bracketchev1221
1,437
1,693
Like was said. You can put the head on first, install the studs with sealant and tighten it down. for a point of reference I would not use studs on any car with fenders unless it was absolutely necessary. I didn’t run head studs on my race engines until the 565 and that was 980 hp and 800 ft/lbs with 1 4 barrel carb.
spongbob
146
82
Upload a picture not shure what your issue is? if you have some double sided head bolts to sandwich a compressor bracket to? you might be stuck useing them( bolts) if the studs are sticking up to far I suppose cut the tops off with a cutoff tool ect. As far as the bolts on one side shouldn't be an issue technically .just take your time systematically tightening in sequences like 20 ft lbs at a time say your torque were 90 start at 50 all way round then got to 65 all the way round then 80 all the way round then last 90. But if you got a car that torque at say 50 you would start torque to around 40 or so then ease up a second sequence ect.
