Headlights
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
I have 4 Hella conversion lenses, for the bulbs I have 2 bi xenon for the hi/lo and HID for the high. The Hella lenses are glass and have a nice beam pattern so the oncoming traffic is not bothered. Best lights I have had on any of my cars and I've never outran them
airboatgreg
2,878
3,123
Did you have to go relays?
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
The kit for the hid comes with relays. Before I went to hid I tried the aftermarket halogen bulbs which worked great until I hit the high beams. The thermal breaker in the headlight switch tripped. Maybe I shouldn't have tried them the first time on a real dark unfamiliar country road. The headlight went back on with the low beams and I wired in relays the next day.
565bbchevy
G-Body of the Month
Aug 8, 2011
9,646
12,782
Michigan
Screw that name brand stuff I am going to save some money and get some cheapy Ebay LED's with no beam pattern that are super bright so I can blind all of the oncoming traffic.;)
  • Friendly
Reactions: 6 users
GuysMonteSS
1,449
1,543
Kentville,Nova Scotia,Canada
1KWIKSIX
235
341
Mississauga , Ontario, Canada
I agree Hella E-code H1's and H4's are one of the best set ups . You can go with or Halogen or LED bulbs .
That's what I used to run and was a great set up!
Or, If money is no object, you could go the full Monte (so to speak).
JW Speaker 4" x 6" LED Projectors.
Best Lighting I've ever had!
Here's a picture of the low beams...nice flat beam with proper cut off , no glare for oncoming traffic.
Plug N Play as they draw very little (no relays or custom wiring harness)
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,229
I have the Hella low/high with the brighter Osram halogen bulbs. I moved the Wagner sealed beams to the high position. I put them on relays to lessen the load on the switch.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,191
9,832
Gainesville, Fl
I have standard Hella H4's currently, but they still could use relays to help them along. They just don't seem bright enough.
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
