So I finally worked my way to the rear of the car,
It’s a 1969 12 bolt from a chevelle I believe since it has the trailing arm mounts on top, it’s obviously shortened, with a Strange Lightweight Pro Race Spool D1549
and Richmond gears, it has 33 spline axles, and not sure what brand c clip eliminaters at the end of axle tubes, as well as using volvo 1205782 rotor and calipers which were from these models
Can you tell me anything else
About this setup? Was this a common thing to use Volvo parts? And is it worth saving/reusing?
Thank you! I can take any other measurements needed for more information, after I remove the spool, what differential do you recommend, I was leaning towards a trutrac?
Volvo | 240 | 1975 - 1993 | |
Volvo | 260 | 1975 - 1985 | |
Volvo | 740 | 1984 - 1992 | |
Volvo | 760 | 1982 - 1990 | |
Volvo | 780 | 1986 - 1991| | |
Volvo | | 940 | 1991 - 1998 | W/o Multilink |
Volvo | | 960 | 1991 - 1997 | w/o Multilink |
