Holley terminator x autometer invision
rizo3506
24
I just got this autometer invision digital dash did anyone by experience struggle using it with Holley terminator and if not can anyone give me some advice on how to connect the engine sensors . Or if there is a canbus unit .sorry if it a stupid question learning as I go
Streetbu
Know it all, that doesn't
3,776
11,841
Central NY
Last I knew they were not compatible with each other. I believe I have seen a canbus adapter though. Unfortunately I don't remember who made it though :/
rizo3506
24
Man that will help extremely , do you have an idea
Streetbu
3,776
11,841
Central NY
Think this is your ticket. But double check me!
johnnunez29
238
53
were you able to get this going? may be interested in the same
bs009
122
232
Smashville
No idea about the canbus stuff but I think the simplest thing to do would be to run a second oil pressure and temp sensor so both the Holley and Invision to be happy. If the Invision used 5v signal based sensors you could tee of the output and feed it to both the Holley and the Invision but it looks like the Invision uses the resistance based sensors so that wouldn't work.
You could feed the Invision the tach signal from the Holley and if you're using trans control with the Holley (Terminator X Max or Dominator) it could give you a speedo signal. The normal terminator X doesn't do any trans control and won't even look at the speed signal out of the box.
Alternatively you could just use a Holley dash screen right?
