OLDS Hurst/Olds Lightning Rod Shifters - Gimmick or Functional?
84 W40
582
795
Wow factor yes, gimmick yes, functional yes when adjusted correctly and even better with a built trans and motor. When my kids were small I had told them the middle shifter was a back seat ejector if they didn't behave. My son asked what the other shifter did the one on right I said thats a special one just for your mother when she doesn't behave it ejects the front seat. So whats my son do runs in the house tells my wife what I just told him she comes running out the house my son behind her laughing. Lucky I had the car running put in gear and took off. True story I still tease my wife about it
Reactions: 4 users
88hurstolds
1,758
675
I have them in most of my cars, when properly installed they work excellent.
Issues arise from improper install or worn out shifter cable, many can't seem to wrap their head around adjusting the shifter cable properly... otherwise if the shifter cable pawl is correctly adjusted they work flawlessly and are a lot of fun riding out the gears in a nicely built TH2004R with a shift kit.
Those that state otherwise aren't doing it right...
I had a dual gate once and hated it, has to be the most useless shifter ever made by Hurst since it's way too easy to jump gears, it's beyond me how they wound up putting them in most of the H/O's.
IMO H/O's should have all been 4-speed cars...
blackonblack
31
40
I'm dropping the transmission pan on my 83 HO in order to fix a leak out of the shift linkage input. I hadn't considered a shift kit. Can you recommend a good one 88hurstolds? Source?
Thanks!
-83MONTESS-
4,570
967
Bellevue, Ohio
My only issue was that you moved them forward. Not nearly as satisfying as slamming them back. Which is why I went with the Kilduff variation.
L92 OLDS
2,872
3,056
West Michigan
You can't beat the coolness factor with anything else but the original Hurst Lightning rods. Fit and finish is excellent and they are built well. Are they faster than a conventional slap stick or performance shifter?...NO. But they look and work great if installed and adjusted properly. Any other shifter in an G body H/O is a wanna be crappy copy and will reduce the value of the car.
