New Windshield! Mirror doesnt fit... 😞
gnvair
1,127
1,345
For anyone that's interested. The GM part# is 9831062 for the original metal mount for the mirror. I found some videos last night. Glass pros say that you can heat the metal mount with a butane soldering torch and melt the glue so the mount will detach. You can do this with out damaging the glass.
565bbchevy
9,633
12,760
Michigan
I just used a Bic barbecue lighter for maybe 10 seconds on the tab and twisted it off with channel locks, it came off no problem.
doood
Amateur Mechanic
Sep 24, 2020
594
816
can we get some pics of the offending part? I may have this problem myself (new windshield sitting in attic right now).
MrSony
6,854
6,793
Des Moines, Iowa
I used a early-mid 90s oldsmobile 88 mirror that fits the tapered pad that I got from the junkyard today. Fits and looks good enough.
57 Handyman
339
389
Wait...what broke? Mirror or windshield? Several thoughts...
Also, a novice using a heat source to detach the windshield mirror mount is a BAD idea. The possibility of damaging and/or cost of replacing a windshield as a result is not worth it. Unless, you're hell bent on original parts, just order a clip on, wider mirror to enhance rear visibility and be done. I kind of went down the same path until I purchased a wider mirror for my 87 El Camino.
MrSony
6,854
6,793
Des Moines, Iowa
I cracked it trying to take it apart and swap bases.
MrSony
6,854
6,793
Des Moines, Iowa
You cracked the new windshield?
No I cracked the mirror the shop gave me when I got a new windshield installed since my old one didn't fit the tab.
