CUTLASS Power Window wiring diagram adding relays to speed up the window motors
69hurstolds
8,324
17,989
While trying to assist in the recent power window wiring thread, I started thinking about how to add relays to the power window system to speed up the motors. So I modified the CSM wiring diagram to include relays.
All you electricians out there, see if it makes sense. I did a quick rendition with MS Paint. Pretty sure this will work, but I ain't no 'lectrician.
5spdCab
1,190
1,993
Tukwila, Wa.
I plan to watch for answers to this question. I have purchased a PW conversion kit for my car. I am waiting for all of the other door parts that I am ordering to arrive before I start because I don't want to remove the door panels more than once. In fact, new panels will be part of the project.
88AZSS
438
1,106
Mesa, AZ
Yup, just did mine with the LMC kit and this is exactly how it’s wired up. Works flawlessly. Thanks for setting this up!
  • Informative
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,996
Socialist NY
I used the Window Turbo
plug and play
no hacking up original harness
  • Informative
Reactions: 4 users
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
plug and play
it cost me under $10 fo0r the relays. Plus the window turbo would not work with my set up with the windows closing with the remote locking and setting the alarm.
565bbchevy
G-Body of the Month
Aug 8, 2011
9,646
12,782
Michigan
I would like to see a video comparison between this and the Window Turbo.
5spdCab
1,190
1,993
Tukwila, Wa.
plug and play
Yeah, I have heard of the window racer plug and play setup. I might do that after I do my conversion. If you are electronically proficient, get hold of a CarTech series book called "Automotive Wiring And Electrical Systems " by Tony Candela. It is one of the workbench how-to's by SA Design # SA160. I was already half decent at electrical, but I learned a whole lot more from his book. You can probably find it easy enough at Eckler's, Dixie, Summit, or Jegs.
TURNA
Jul 24, 2009
10,941
19,996
Socialist NY
That is awesome.
I just dont like cutting things that dont need to be
565bbchevy
G-Body of the Month
Aug 8, 2011
9,646
12,782
Michigan
there will not be any difference since the source is the same and neither add any power.
I would still like to see it in a video and compare the speed to mine
