Race-only A-frame bushings
Sittin Duck
13
15
My age is going to show. Back when 55-57 Chevies were more common at the dragstrip, one of the old suspension tricks was to grind the "teeth" from the inboard side of all four a-frame bushings, to allow quicker front end rise on the starting line.
I am going to rebuild the front end of my (Drag only) 80 Malibu with new Comp. Eng. 3-ways and Moroso coil springs. It would seem to be a good time to do ball joints etc.
The A-frame bushings appear to be original but having not disassembled them yet, I don't know if the above exercise is even possible or beneficial.
If this setup does not permit the above, what are you drag-only guys putting in your stock A-frames?
Thanks for your time.
  • Wow
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
458
  • Wow
bracketchev1221
1,429
1,679
The teeth grinding still works. There are other options like Del-a-lum bushings, but I went 1.21 with my stock front end chevelle with rubber replacement bushings.
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Yeah, there a tonne of low resistance options out there today - from bushings to ball joints.
The question is how much money or time do you have?
melloelky
4,183
9,635
mass
there was a certain wagon that used to pull the wheels on the regular,after selling the car he posted a picture claiming the removal of the bump stop area in the upper freed up a lot of travel.it's cheap and if you're clearancing the bushings your already there anyways.
  • Wow
