Rear side exterior window trim
85ss/85gn
293
258
beaver dam,wi
Have a 81 Malibu wagon been picking up extra parts. Have two different styles of trim. What year did they change?
85ss/85gn
293
258
beaver dam,wi
Anyone?
81Regal
1,558
485
83
Terril Iowa
Pretty sure it was 81 when they changed from the metal trim to plastic/rubber.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,185
9,819
Gainesville, Fl
I always thought it was later, like '82, but you might be right about that, Jake.
'81 could be the year that they went with the crappy flexible quarter window side mouldings..
What a mistake. But I guess the GM bean counters saw that they could save a few cents by going with the flexi-crap.
PBGBodyFan
788
1,221
Wisconsin
My 81’ has the flexible seals. New to wagons and didn’t think they are inferior but the “chrome” is peeling/discolored. I have a couple sets of the other style in case I really decide I prefer it.
Longroof79
Oct 14, 2008
12,185
9,819
Gainesville, Fl
Guys have chosen to go with the early style ('78-'80) metal mouldings. However, it entails having to install studs to accommodate clips to hold them on.
The problem with the flexi type is that they do become compromised and you can't reuse them once they're removed. Plus. they can no longer be obtained, so your choices are limited.
There's at least 3-4 guys from this forum that converted to the early type mouldings.
85ss/85gn
293
258
beaver dam,wi
Ok thanks
The clips like used on the windshield and rear windows on 2 door g-bodys?
Longroof79
Oct 14, 2008
12,185
9,819
Gainesville, Fl
Ok thanks
Same clips. You can use the screws which act as studs to hold the clips on. Usually they're sold by companies that sell the clips. They're specifically made for that purpose. I'll try to find what I'm talking about.
https://www.amazon.com/dp/B00THJNNN6/?tag=gbody-20
I hope this link helps you out.
Somewhere in my notes I made note of the dimensions where the studs are placed on the window frames, etc.
Ribbedroof
4,951
7,132
Wellston, OK
81+ got the vinyl moldings, 78-80 got the aluminum.
There is/was a guy on the G body wagon Facebook group that was selling some sort of molding sets that he made
Longroof79
Oct 14, 2008
12,185
9,819
Gainesville, Fl
Brian,
Does he mention what the mouldings are made from? Also, If you find his listing, can you post a link to it?
