starter clicking , no crank
michael_boomin
17
trying to start 78 el camino (350) . battery is reading 12.4 at battery and when read at starter. the problem is when i go to start, the starter clicks repeatedly and never actually cranks. while connected to float charger the battery some times reads at high as 14.5, gets momentary attempt at cranking then continues to click. starter was replaced a year ago after the same issue and worked for about a year but with minimal use. after starter was changed ,a few wires to starter (fuseable link?) burned on headers and stopped working after i repaired them (worked while burning on headers) . looking for help on fixing this issue. i don’t believe it is the battery that needs replaced but seems like it may be wiring issue. all advice is appreciated .
ck80
Moderator
Moderator
5,757
9,167
Initially speaking, your battery doesn't seem to have the juice to start. Try some jumper cables, not just the charger and see if you start. Likelynwill.
That accomplished, check the grounds well for cleanliness and contact tightness. Your step after that would be hunting parasitic drain, maybe starting by poking around thebaltern a tornwith a tester
dmac35242
25
39
13
Birmingham, AL
I'd put a jump on it.
If that doesn't help, I'd remove and clean all associated grounds.
Still no bueno, remove starter and have tested at parts store.
Good news is you've got the click so you can feel good about the switch wiring.
