Stock 2bbl to 4bbl intake & Holley ~What I learned
Low_Bridge
Jan 22, 2014
69
13
8
Backwoods
What to look for-
Mainly concerned if all the electrical stuff unplugged when the intake & carb was pulled.
Is it wishful thinking that just plugging the original distributor back in & she'll fire away?
This is the daily Driver
4.4 Malibu Classic Full Power
Mission:
Remove sick stock 2bbl carb & intake
Replace with Wieand Action Plus Dual Plane square flange & Small Holley
Thanks for the help!
Before Picture Now Attached
Judge Mills
199
Washington State
I just swapped a vacuum advance distributor for the stock on in my 81' El Cam with a 305 last night and it runs great. I bought it with a Holley carb already on it.
Unfortunately, I don't know anything about the 4.4L. I'd assume it'd run without, but I can't confirm.
Low_Bridge
Jan 22, 2014
69
13
8
Backwoods
Manifold is on
Being a daily Driver the air is in Tact
I did not test fit the Engine lift bracket that also bolts to the back of the a/c compressor
Had to grind for clearance due to larger manifold boss.
NEXT Concern:
Original Throttle Bracket did not seem to match new manifold bosses
Low_Bridge
Jan 22, 2014
69
13
8
Backwoods
  1. Stock Manifold heat shield did not Like Studs for Valve covers & using gasket
  2. Boss for alternator bracket on front of manifold (Wieand Action Plus Dual Plane square flange) did not line up. Grinding elongating hole required.
Low_Bridge
Jan 22, 2014
69
13
8
Backwoods
So once I plugged in those solenoid lookin things I had hoped to eliminate in the wiring harness, she fired right up & purred like again.
Found a throttle bracket layn round that worked better than the stock
A little more tidying up with the throttle linkage et al & a road test it is.
ssn696
Living in the Past
5,560
6,726
Permanent Temporary
Way to go! That's how I learned this stuff 30 years ago.
I have a rebuilt 6.2 diesel and complete Banks turbo kit in a box. Have not figured out what to do with them yet.
Low_Bridge
Jan 22, 2014
69
13
8
Backwoods
I started with a 69 Camaro in 1975 in the Garage of my aunt at the Jersey Shore in the middle of the winter.
It's retro-ing these later rigs & figuring out what I can eliminate without hacking into the wiring harness:confused: is the mystery!
