Trans cooler lines - leaker ....
WanaBa442
556
1,318
New England
Got the new rad put in and had to piece in a new section of trans line at the lower fitting as the old one rusted/twisted off when I removed it.
I can not get that sumbich to seal up:mad:
Short of replacing the replacement line, any words of wisdom from the masses?
565bbchevy
9,634
12,760
Michigan
How did you go about doing the repair? Pictures?
g0thiac
939
582
Get some 5/16ths hose and use that. Transmission rated if you can.
WanaBa442
556
1,318
New England
Leaking at the rad connection. Have new piece of steel line with new fitting there.
I have a feeling there's too much pressure on the steel line causing it to not sit straight on the flare inside the connection and the nut is not seating it tight.
IIRC, I saw a copper cone shaped crush washer for use on a master cylinder port to help seal those if the port is out of round or a bit corroded, but cant remember where I found/ saw them...
I'll hit it again tomorrow and take it apart, seat the line first and then the splice.
565bbchevy
9,634
12,760
Michigan
You didn't by chance cross thread the fitting while installing?
melloelky
4,190
9,661
mass
WanaBa442
556
1,318
New England
So, rather than let the thread die with no updates I'll let you know what happened.
I was using a new steel line section from the rad to a compression fitting on the existing line which was in good shape other than where it broke at the rad fitting.
I carefully had measured and bent the replacement line to what I had taken off, connected it to the compression fitting and then into the rad (which is where my leak was, around the tube and nut).
So I went this AM and got a section of NiCopp 5/16 line 'cause it bends easier and figured I could line up the angle of the line into the rad better and get a better seal.
While it was apart I figured I'd try and put a stub section of line in the rad for a reference point and found out WHEN THE NUT WAS FULLY TIGHT, THE TUBE WAS STILL ABLE TO MOVE!
Turns out as this rad was older stock that sat around there was corrosion around the cone seat and the last few threads that would make the fitting seem like it was fully seated and tight, when in fact the tubing wasn't seated fully before the nut stopped.
Kroil, fine thread chasers and a few cups of coffee later we got it all back together, test drive and no leaks :cool:
Just one of those stupid deals where you think new parts are always perfect (even if they're old, new parts).
Moral of the story, check the little things. Nobody like to be known for their motto " We do it nice 'cause we do it twice" :blam:
565bbchevy
9,634
12,760
Michigan
Usually new radiators come with everything capped and threaded inserts on the trans lines to protect them. well at least you fixed it.
