Weather stripping needed for passenger door
tkruger
358
310
NY
1987 Monty Carlo
I need the door weather stripping for just the passenger door. Mine was recently damaged and needs to be replaced. Is there anywhere that I can just buy the one side? If I do have to get both sides any recommendation on what the best available ones are?
69hurstolds
8,326
17,993
NOS GM are the best, hands down. And before you start to think 150 bucks is too much, then you'll see why it's worth it when you cry trying to make others fit and function. Pay once, cry once, but it will be RIGHT the first time. Olds and Buick door seals are north of $200 each if you can find them. But hey, it's your car, do what you must.
GM p/n 20277448
tkruger
358
310
NY
I understand the GM verse remanufactured. I tracked down some for the windows that was GM original, hope that stopes the wind noise once I have a chance to install it.
Unfortunately the passenger doors was accidentally damaged and I need to replace that one side. Drivers is ok.
69hurstolds
8,326
17,993
Sorry, I thought you meant the door weatherstripping that wraps around the bottom and sides of the door. If you needed the top of the door window sealing strips, that's another ball game altogether.
tkruger
358
310
NY
The bottom one that wraps around the door is the one I need. I just found the window ones recently. The lower door weather stripping caught on something when someone was getting in the car and ripped. I need to replace it before there is an issue.
69hurstolds
8,326
17,993
