wiring diagram for gn fans
84cutspreme
1,162
155
does anyone happen to have a schematic for the wiring on gn electric fan?
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
One post is power and one is ground. You'll need a 30-40A relay and fuse, and a switch on either of the leads... ground side is recommended.
84cutspreme
1,162
155
UNGN
3,048
3,268
Southlake, TX
Thank you!
I just wish it was scanned with a little more Resolution. GNtype.org has been around since almost the beginning of the internet and files size was pretty limited back then. I'll look to see if I have a higher res version around here.
84cutspreme
1,162
155
nice thats exactly what i was looking for!! thanks! i have whole book for cutlass but im in the middle of installing gn fan n want to have low and high on fan. just wasnt sure if it worked off ground or power with relays
84cutspreme
1,162
155
another question. how was fan originally mounted? does connector face down on driver side or up on pass side? if anyone has pic of stock electric fan installed it would be much appreciated
