BUILD THREAD 84 Regal back half/caged/mini tubbed lq4/4l80e build
5,717
12,241
How does the ECU control line pressure?
Roblq84
Oct 29, 2023
73
143
33
5,717
12,241
I’m able to increase it by percentages at different tps ranges per each shift
Hopefully you have it near maximum by 75% throttle. It’s worth checking with a manual gauge at the transmission. Even if the software is setup correctly, an internal issue that causes low line pressure will burn up every automatic trans.
