I’m able to increase it by percentages at different tps ranges per each shiftHow does the ECU control line pressure?
Hopefully you have it near maximum by 75% throttle. It’s worth checking with a manual gauge at the transmission. Even if the software is setup correctly, an internal issue that causes low line pressure will burn up every automatic trans.I’m able to increase it by percentages at different tps ranges per each shift
