15x10 tire and rim fitment
nycutlass
594
157
NY
Has anyone put a 255 tire on a 15 x 10i rim with pictures? I'm wondering if it looks stretched. also if anyone running a 10inch wide rim without a frame notch i think a 5in backspace would work. i just mocked up a 15x10 rim with a 5 1/2 back spacing with no tire on it and it was 1/4 off the chassis i was completed surprised. this is on a 83 cutlass with no mods done.
  • Wow
64nailhead
Goat Herder
Dec 1, 2014
5,724
12,258
Upstate NY
I run a 15x10 with a 275/60 without a frame notch - 84 MC. My backspace is not relevant though because I don’t have a stock axle width.
Local Hero
729
1,917
Northcoast, Cleveland, Ohio
I run 275s on a 15X10 on the back of my wagon. It does have a notch. Personally I feel a 255 is more suited for an 8" rim. 275s fit perfectly on a 10.
scoti
1,988
3,429
Texas
15" 255's on a 9" wheel. They would def looked stretched on a ten.
275's are a nice square fit on a 10" wheel.
nycutlass
594
157
NY
the part I'm unsure of is if anyone put 15x10 with a 5in backspace without notching the frame
DSPbuilt
572
1,556
Cape Coral, FL
Give me a few and I'll post a pic. 4.5 BS seems to be the sweet spot. About 1/2 inch from the frame. Didn't rub with the 275/60 Nittos( nitto tends to be on the slimmer side ).
nycutlass
594
157
NY
i already bought the rim 15x10 with 4.5 BS and it did not work. i ended up returning it. my friend has a 15x10 5.5 BS and it was 1/4in off the frame and had lots room on the fender side so I'm assuming if i did a 5in it would work
scoti
1,988
3,429
Texas
i bout the rim 15x10 with 4.5 BS and it did not work i returned it my friend has a 15x10 5.5 BS and it was 1/4in off the frame and lots room on the fender side so I'm assuming if i did a 5in it would work
Disclaimer: My experience/images are with/on a Malibu.
I put an 18x 9.5" wheel w/5.25"bs on the stock width 7.5 housing under my 78 Malibu Classic. It fit w/minimal clearance when just doing the initial check. There was enough room behind the bare rim edge for my finger/s @ its closest point.
Included is a 2nd image of where it is @ the fender lip. The lip on the car is already trimmed about .375" (just beyond the spot welds). I was converting to LS1/f-body rear discs which would push it ~.250" farther away from the frame. But, more clearance on the inside yield's interference sooner on the outside edge.
Ride height will also play a variable in the 'will it fit' game. Stock height cars can allow you more wiggle room vs the same car lowered.
64nailhead
Goat Herder
Dec 1, 2014
5,724
12,258
Upstate NY
FYI - a 1/4" of room is plenty as long as your upper a-arm bushings aren't worn out or you don't plan on filling the back seat with 3 fat people.
edit - 1/4" of room from the tire, not the rim.
81cutlass
4,654
13,596
Western MN
I have 15x10 5" BS wheel vintique Pontiac Rally with a 275/60 Drag radial.
I need to run a 1/4" spacer or the tire hits the frame. The wheel clears fine. Even with the spacer I have a clean spot on the frame where the tire rubs when the tire shudders and wads up.
