1976 olds 455 hp rating.......
tlonz88442
Hey guys do anyone know the true hp rating of a 1976 olds 455 engine stock .....also is this year engine desired as well as some of the earlier versions of the 455..
L92 OLDS
2,872
3,051
West Michigan
Putting early heads on this motor will not necessarily correct the crappy compression ratio you have as a result of the large dish pistons in the 1976 smog 455. The chamber volume of most factory and aftermarket heads (that you can find and buy for a reasonable price) is actually quite similar. Even if you put aftermarket aluminum heads like the Edelbrock and the Procomps on it with a large 77cc chamber you will still have a low CR . The block and crank are a good foundation for a build though. For a performance build, you will want to swap out the big dish pistons. In 76', HP was low relative to the engine size but torque was huge.
If it was a small block Olds (403 CID) you can bump the compression ratio up using early heads. Chamber volume varies from 1967 #4 casting (60 cc) to a 1976 403 - 4A casting (83cc)
tlonz88442
Thanks guys very much ... what pistons would be a better choice without breaking the bank..
DoubleV
2,154
406
83
Medina Ohio
IMO I wouldn't mess with swapping in new pistons unless you're doing a complete rebuild with proper machine work and all. Even a stock 76 455 with the proper tune, bolt-ons, and gears will be a fun ride unless you're one of those guys who needs a really fast car. If you're happy being in the 13's with lots of street loving torque, I wouldn't rip it apart ( though I would slap a new timing chain on it ).
