1979 century wagon
Tberstler4
11
12
If its your intention to convert the car to SBC, and it has the 301 Pontiac in it now, I would say don't do too much with the Pontiac engine, other than keeping it running, until you do the swap. There is very little on the Pontiac engine (other than probably distributor cap & rotor), that will be transferable to the SBC, and that includes engine mounts and accessory belt drives. Good luck with your swap.
Will the stock fuel system from the 301 work for a stock sbc ?
clean8485
2,863
2,158
Ontario, Canada
Depending on which side of the engine bay that the original engine's fuel pump and starter are on, you may have to re-route some of the fuel line(s), and some of the engine wiring harness, to accomodate the replacement engine.
stew86MCSS396
178
242
(808)
If the 301 is anything like my Poncho 350, the starter is on the driver's side so you might need to lengthen the wires to the passenger side of the SBC. The fuel pump on my Poncho 350 is same side as the SBC but on the Poncho, it is located on the rear of the block whereas the SBC it is on the front so you need to perform some modifications to the fuel line plumbing to make it all work.
oldsmobile joe
2,067
3,053
mpls
WTF!? Since when? Oh i gotta see a pic of this.
stew86MCSS396
178
242
(808)
Oh crap!!! I'm a retard!!! As the engine sits in my driveway with a tarp over it, I took a quick glance at it and assumed I was looking at the back of the block when I was really looking at the front. Sooooo...with my head screwed on straight fuel pump is on the front of the block driver's side.
SS_Malibu
1,181
2,081
Mesa, AZ
We can just write that off as years of brain abuse in your younger days (or currently). Lol.
SS_Malibu
1,181
2,081
Mesa, AZ
Tberstler4,
I still have that split bench seat if you want it. Otherwise I'll strip some parts off it and throw the seats away. I have nowhere for them.
oldsmobile joe
2,067
3,053
mpls
Lmaf, been there, done that.
