CUTLASS 1983 Cutlass - windshield wipers woes
ELCAM
1,137
1,295
The spade terminal i have marked "to relay" is probably the gray wire. The red wire goes to the relay but the rest is a mystery. The schematic shows the relay being part of the motor but all the parts data shows it is not part of the motor.
Perhaps someone has a picture of a relay installed?
You should be able to get the regular non delay functions to work so you at least have wipers. Then you can figure out the relay.
CurtisP
15
12
Bumping this thread - I put the car on the back burner and was super busy with my machine shop and the farm equipment.
Will be going back at this shortly - ELCAM do you believe I need a different wiper motor for the wiper switch I have in the column ?
There is a few options available I would like to just buy a new one and make sure it’s correct
CurtisP
15
12
Alright,
After a full day yesterday devoted to the car in the shop. Dash wiring removed, cleaned up, fixed properly.
Fixed many poor grounds throughout the car as well.
However - the circuit board on the wiper motor is no good now, I suspect one of the resistors is smoked out in it.
A lot of searching online yields just a motor assm without a new circuit board setup, does anyone have a complete assembly option ?
Kicking myself now for not changing the dash light bulbs to LED while it was out,
pagrunt
9,299
15,778
Elderton, Pa
Ever thought of replacing the mechanical washer pump with an electric one like Trico's 11516 ('80-'83 A/G w/delay) as it has everything for the delay to function like the mechanical pump. I've installed one on the motor I'm using with my delay conversion.
CurtisP
15
12
I am not familiar with that one - will it replace the whole circuit board. ?
pagrunt
9,299
15,778
Elderton, Pa
Everything is attached to the pump part of the wiper assembly so all you need to do is remove the wires from the mechanical pump to swap out to the elctric pump. I unsoldered the black/purple wire to add a uninsulated terminal to connect to the red wire that has the flag/side terminal. Now Rock Auto does have a circuit board kit from ACI, p/n 172360, that will get you wipers working again with out messing with swaping out pumps.
