Here’s the most recent project taking up shop space.
It was my daughters’ first vehicle. When the Ex-boy friend knocked the rods out of it shortly before they broke up I picked up another car for her and took this in as partial trade on it. I never got around to selling it or parting it out so it just sat in the back shed collecting dust for the past 10 years or so.
It’s an 87 Ram 50 (really a Mitsubishi Mighty Max) that Dodge imported from Japan and slapped their emblems on.
This spring I decided to drag it out and build it as a project with my oldest grandson. I’m too much of a hot rodder not to put an American V8 in it. The kicker is that the engine compartment is really short and I was determined to retain the factory AC (which meant the radiator could only move so far forward). . Although I’d have rather used a Mopar engine because of the Dodge badging after some measuring it was determined the SBC was the shortest engine out there and would let me keep the AC. That actually worked out well for me as I had a couple of Small Blocks laying around . Originally I had planned on rebuilding the 305 roller motor in the back shed but decided to go ahead and use the little hot rod 283 my grandson and I had built as a project a year or so ago.
The truck came with 3.90 rear gears so an overdrive transmission was pretty mandatory, and I eventually settled on a T5 5 speed.
Like most of my projects, this one got more and more involved as I went along. When I found out the original gas tank only held 13 gallons, I decided to add an additional 20 gallon tank between the rear frame rails (the fill neck is behind the license plate).
The T5 I ended up with was a later one that set up for the electronic speedometer and coming up with the parts to convert it to a cable speedometer proved harder than I thought it would. I eventually decided to just go with an electronic speedometer…..and of course I might as well add a tach and gauges to go along with that.
And it was a radio delete truck so it also got a new stereo speakers and wiring.
Anyway I got it running Sunday…….just a couple trips up and down the driveway for now until I get it registered. It seems like it may have the same issue as my caddy powered El Camino……traction.
I’ll probably drive it for a couple of years, then it will eventually go back to my daughter when I get tired of it (it still means a lot to her).
