BUICK 231 Breather Hose
ssn696
Living in the Past
5,551
6,692
Permanent Temporary
Molded hose that runs from air cleaner to 90 degree valve cover fitting. In search of a part number. I looked for one in the Dorman catalog and I find nothing for this engine. Similar hose that can be cut down for this application? It has two 90 degree turns orthogonal to each other if you can’t tell in the picture. 1D490BF5-DD29-42D9-ACAA-CADACF4DA849.jpeg
jiho
1,002
508
A coolant bypass hose with two 90* bends, for the older-style intake manifold that has a vertical water outlet mounting surface, is also hard to find.
69hurstolds
8,230
17,693
85-87 uses p/n 25521457. Again, have no idea what the difference is.
ssn696
Living in the Past
5,551
6,692
Permanent Temporary
Immensely useful. You should change your userclass to GM Oracle. In desperation, a segment of radiator hose has been made to work.
1,167
2,638
West Virginia
For a second I thought you said ‘GM Orifice’............and I was thinking geez dude.
