3970010
83gbody
156
Oxford, Ms
Can anybody tell me bout this block 3970010 or tell me what other numbers to look for and where?
83gbody
156
Oxford, Ms
It's say 69-79 350 but its a 4bolt main
GhettoRacingKid
775
7
they came in 2 bolt and 4 bolt mains. I believe they also used that number for the mexian blocks.
if you look behind the timing cover or the flywheel/flexplate and see a 10/20 thats the high nickel block. strongest block they made.
they are good castings.
GT_80
240
7
Massachusetts
Ditto- I have had 2 of those blocks, both 010 'high nickel' block- One a 4 bolt (bored .060 over), one a 2 bolt. Great blocks!!
I still have the 2 bolt as a bare block- need to be machined because the previous rebuilder did a shoddy job rebuilding it- the rear main bearing spun so bad that it has about .010 deep grooves in it. I would sell the block to anyone who wants it for $40 just so I don't see it go to scrap! You could line bore it and stick a 400 sb crank in it to make a stroker
seawolf18
271
4
SE South Dakota
A 3970010 is the most common block i've seen for a gen 1 350. They are starting to get harder to find now days. if its a 10/20 block they are even more difficult to find. They came in 2/4 bolt main, and 2-piece rear main seal. The only way to tell how many bolt main is to drop the oil pan and look. They yards around here were stuffed full of them 8-10 years ago. Now days not so much. When I come accross a rebuildable one, i'll pick them up if the guy doesn't want too much for it. I've seen people trying to sell them for $300-$350 bucks for a core lately. People think $1.00 per cubic inch is the going rate now. However, they don't move them unless a person that doesn't know what they are doing is looking for one.
83gbody
156
Oxford, Ms
It was built August 5 1974 and its a 4 bolt main
GT_80
240
7
Massachusetts
if it is rebuildable, it's worth buying. I paid $200 for my .060 over block with cam bearings, and new freeze plugs installed, fresh from the machine shop because he bored it for a customer that never came back, and wanted something for it... Score and a half! I just sold the short block for $350 cash and a good stb bore 350 short block.
G_Body_Enthusiast
1,056
16
38
Louisville, kentucky
i have a standard bore 010 block, 10/20 too. only downside is it's a 2 bolt main but that isn't a big deal. i got it as a short block for a measly 50 bucks. i thought it was a good price given it's still standard bore.
