7.5 7 5/8 ring gear
jimmyp618
136
Anyone know if you can put a 7 5/8 ring gear on a 7.5 carrier and swap out pinions? Thanks
jimmyp618
136
never mind found my answer it will work
GM 7.5" Ring Pinion 3.42 Ratio 41-12 Teeth For 3.08 Ratio and Numerically-Lower Carriers
GM 10-Bolt 7.5 7.625 7.5 7.625 Diameter Ring Gear 1.438 Pinion Diameter 27 Spline Pinion 10 Bolt Oval Cover Fits 77-02 All GM models 82-02 Camaro/Z-28/Firebird/Trans-Am 83-02 S-10/S-15 rear 85-02 Astro/Safari 77-87 El Camino Will not fit Monza etc.
