Hi!
Trying to make a conversion to delayed wipers on my ‘79 Cutlass Supreme. Got a new wipers motor with delay option from Rockauto, got a switch from abandoned ‘80 Cutlass sedan but nothing happens. First of all I saw that new motor has two more additional connectors. The first is for green wire and the second one I connected to “+” when ignition is on (is it right?). As a result I got no changes - in delay position wipers runs as in “Lo” with no delay (see the video below). What’s wrong with them?
The other issue with corner lights and cluster backlight. When I turn the ignition on, corners and cluster backlight starts too. I can regulate the brightness of corners with the dimmer switch but backlight stays always bright
Can you help me?
Some pics:
And video:
Can you help me?
Some pics:
And video:
