GRAND PRIX 79 Grand Prix Resurrection
CDUNIGAN1981
307
347
Still surprised guys are only seeing a 150 rpm gain, I always see 250 to 300 rpm on different vehicles and tachs. I am currently using the TCI lock up kit in my 88. It works quite well but the vacuum switch will need adjustment with your bigger cam. What shifter are you currently using?
I'm in the air about my shift. My factory slapstick is for a 3 speed.
I would love a quicksilver if I can keep it under console but have also considered a factory 4 speed shifter out of a newer Grand Prix.
CDUNIGAN1981
307
347
Interesting question.
I'm still learning but am trying to find this.
I've been reading about rpm range all morning. The guy who built my motor was a pure Pontiac guy but I'm no longer in touch with him. Wish I could get back in touch.
With that, my cam is a Lunati as follows.
I'll continue to read. The technical direction on this site forces you to read about things which has been great.
I've learned so much in the past year from immersing myself into the internet.
Whats the RPM range of your cam?
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,996
Socialist NY
If you are cruising out of your RPM range your going to chug
So if your cruising at 1600 RPMs but your cam is made to run at 2200
Your car is going to chug chug chug along
Find out the cam part number and look up the correct RPM range
Then you can make a choice
  • Informative
TURNA
Jul 24, 2009
10,941
19,996
Socialist NY
Also what rear gears are you running
TURNA
Jul 24, 2009
10,941
19,996
Socialist NY
Well then you want 4th gear to be 1800ish
  • Informative
