'80 Lemans Tear Down
deanlemans81
603
201
Acton Vale, Quebec, Canada
doesn't progress feel good. even if slow. like the way you suport the shell for access.
tdvick
344
126
Elk River, Mn.
Got the inside of the floor coated with POR today. Need to epoxy prime everything else now. Slow progress...
tdvick
344
126
Elk River, Mn.
Another little addition. Bought this a couple years ago and figured I should actually put it on...
tdvick
344
126
Elk River, Mn.
Piece by piece. I bought the UMI anti-roll (drag bar) bar about 3 years ago. Finally installed it today. Another step closer to dropping the body shell back on the frame...
Kiko
300
341
Ottawa, Canada
Very nice! The question I have (pardon my ignorance) is why are your upper control arms mounted on vertical extenders? Is this for a reason or is it how they were sold? Thanks,
tdvick
344
126
Elk River, Mn.
I think you are asking about the "no-hop" bars. They are used to correct the factory geometry of the control arms. They help the rear end plant downward at launch instead of trying to hop up and bounce. I can't explain it completely. There's theory behind it, angles, triangulation and stuff... They worked on my old GTO so I figured it couldn't hurt to throw them on this too.
Kiko
300
341
Ottawa, Canada
So the "no-hop" bars are what connects the 3rd member housing to the upper control arm? They basically lift the UCA in the vertical plane...
tdvick
344
126
Elk River, Mn.
Yes,
They attach to the center of the rear end housing and move the mounting point of the upper control arms upward. Changing their angle improves the reaction of the chassis under hard acceleration.
