80 Regal's new wheels / The Czech Republic
tnovotny
29
Prague, Czech Republic
Hi,
I just wanted to post my new wheels on my daily drivin 80 Regal 3.8 Turbocharged.
Im trying to figure out how low this car can go and still be able to drive our bad bad roads.
I put some used BMW (I never thought I could do it) 15". And I like them in the end more than some cragars or mangels or originals.
And I put 205/50 on front and 205/60 on rear.
I will be happy if you tell me what you think or what could be done better.
Maybe I will yet go with 2" drop spindles or I have set of Eibach lowering springs.
Thanks!
pontiacgp
blank
Mar 31, 2006
29,270
20,417
Kitchener, Ontario
the bmw bolt pattern is 120 and not the same as the G body's 127 bolt pattern. The wheels will bolt up but it puts stress on the wheel studs and I don't think the hub centers are the same size either. If you have the eibach springs why not install them and see how you like the ride height.
tnovotny
29
Aha..I didnt know that at all. I just converted GM inches to cm and thought its enough. What do you think can happen? Isnt it dangerous?
I had opportunity to buy gm wheels, but didnt like em much..
Springs are actually not mine yet. I bought wheels first, because I just couldnt decide where to start.
pontiacgp
blank
Mar 31, 2006
29,270
20,417
Kitchener, Ontario
I would not run the BMW wheels since they do not fit properly. If you can get the eibach springs at a good price then why not try them, lots of people have them and they don't complain. I ran with the eibachs for years and switch them out to moog cause I was doing something different.
CWPottenger
848
323
Actually the GM bolt pattern is 120.65 in Metric Which is not a huge difference @ .026 of an inch across. There is that much "slop" in a bolt pattern. Now if the hub centers are different you need to get an adapter.
pontiacgp
blank
Mar 31, 2006
29,270
20,417
Kitchener, Ontario
My mistake, I forgot a 0.....if they used flat wheel nuts then .26 isn't much but since they use taper nuts then it does become an issue
http://www.pro-touring.com/threads/5080 ... w%20wheels
"BMW's 4.72" BP was "good enough" for the 4.75" hub.
Here is the stud using a 4.75" BP wheel. Note the stress concentrations at the chamfer resulting from 10,000+lbs of tension. These results are typical."
