BUILD THREAD 86 monte carlo ls basket case
Drkuhar
512
913
Girard, IL
Well the dash is better than what i had , so thats a plus. I had to add some screws in places down low and a couple in the center above the radio. I got a coat of paint on it and hopefully when assembled it wont stand out to bad
Reactions: 4 users
mclellan83
4,279
9,515
Pgh, PA
Doesn't look too bad, but since you had it out I would have given a shot to just fixing the cracks and see how it would come out since you had the backup of adding that after the fact
Drkuhar
512
913
Girard, IL
I got the transmission cleaned up and painted, new filter and pan gasket. New front and rear seal , dipstick seal, kickdown seals and the speedometer gears changed so the speedometer will be accurate. Got the new u joints in the driveshaft and got it painted also.
Reactions: 5 users
Drkuhar
512
913
Girard, IL
Engine and transmission is in. Monte front ends must be longer than cutlass front ends as i had to pull the header panel and bumper to get the cherry picker close enough to set the engine in(never had this issue on my olds). Filled transmission and found a huge puddle the next morning. I think its leaking at the shift shaft seal. The only seal i didn't change of coarse.
I also got the wiring under the hood fixed and routed. Headers are on, oil and coolant senders are in and wired.. had to get a new distributor and picked up a supercoil. And both got damaged in shipping but usable and the hole in the floor from the stick shift is welded up and the floor is wire wheeled and coated with por15 and painted.
Made good use of the president day weekend
Reactions: 6 users
Drkuhar
512
913
Girard, IL
Well i have 2/3 of the interior in. Back seat, sail panels, rear seat, headliner, dash, and domelight. I have to do the wiring terminal rearranging on the dash plug since i am putting a rally cluster in and hook up all the dangling wires under the dash.
Engine bay side has the wiring harness fixed, engine accessories on. This weekend i hope to get transmission lines made and ran.
Reactions: 5 users
Drkuhar
512
913
Girard, IL
Been a while. I finished up the engine wiring, shifter mounted and adjusted , speedometer cable ran but I need the grommet for the large hole on the firewall. And I got brave and cut the hole in the hood for the scoop . No turning back now lol.
Next thing is fuel sending unit in tank and vacuum lines to modulator
Reactions: 6 users
