MONTE CARLO Alternator
Flynnt50
10
If you need to get another alternator you could upgrade to the AD244, it uses the same plug and is not supposed to need the resistor. I have an AD244 and with the CS144 that I was using I had the resisitor so I used the same sire witht he reistir for the AD244 and it working great but I have read the AD244 doesn't need the resistor.
Really that sounds like a great idea
pontiacgp
blank
Mar 31, 2006
29,270
20,418
Kitchener, Ontario
If you can find a local shop that rebuilds alternators they can help you out better than a parts store and you'll get a better alternator. You can be sure if you kept showing up at a shop with burnt alternators they'd be asking you about the set up.
Flynnt50
10
If you can find a local shop that rebuilds alternators they can help you out better than a parts store and you'll get a better alternator. You can be sure if you kept showing up at a shop with burnt alternators they'd be asking you about the ok
