I hoisted the engine on the exhaust manifold bolts as I've done many times when I heard a slight compression hiss followed by a mixture of oil and coolant pissing out of the water pump. Could I have seriously blown the gasket or damaged the heads simply from hoisting the engine on the exhaust bolts? Sounds ridiculous but I saw it happen.
Pulled off the water pump, timing cover looks fine and water pump had a bit of oil sitting at the bottom but the inside of it looked clean.
I couldnt be more puzzled, any comments or ideas on the topic?
