Budget LS1 swaps
dogsht
2,003
9
36
Dayton, OH
Yea always frustrates me when we get hung up in the letter of the law and forget what the original law was meant to do. Yea they put a lot of 5.3s in trucks but I would not call it a truck engine. Too small and in lack of sufficient low end torque. Every try and tow with one. Also they did/do put them in some cars.
GbodyVet, Yea FI is generally preferable for a daily driver capable street car but you can get and I have had carberated setups that started up well in the cold had great drive-ability ie responsiveness and part throttle as well as good economy. It was a professionally built & setup for my combo electronic choke Q-jet. Not as good as modern FI but just saying because much of our younger audience may have little or no experience with a carb. Many today only have experience with a ill set up for the car race carb that sucks at everything except WOT or an in need of rebuilt refresh old leaking seals carb.
skatepirate77
Mar 12, 2010
66
I found out in utah it really doesn't matter about the engine just if the car can pass visiual and the sniffer. They do emissions on the year of the car not the engine. Also have a buddy that will pass me. You should some cars that pass out here there exhaust is laying on the ground yet they still pass.
85GPLef41
2,210
159
Colorado
wished it was like that around here...I have to find and adapt all the emissions equipment for my LS1 swap, And it cannot be from a truck...
skatepirate77
Mar 12, 2010
66
I just found out last week I could use all my original emissions stuff to pass the sniffer. Yeah for emissions right? :puke: :blam:
G-Body_Vet
2,937
81
48
T'is true! What I'm getting at is the cost vs benefit. For instance, the rebuild on my 455 is going to send me into the $3K+ range easily. If I wanted to go EZ EFI and a roller set-up the price climbs with it....like another $3K. If I want to go with Edelbrock d-port heads, add another $2-$2500k to it. Then I can't run an OD trans without having it built to handle the torque.
If you get a hold of a 5.3 w/ a 4l60E you have a roller set-up. FI, modern heads, lighter weight, a trans made for the engine, etc. Of course it won't be a drop in deal like a carb set-up, but for the cost it's not bad.
I think I just want to try something more challenging next time around.
85GPLef41
2,210
159
Colorado
You could use your original equipment? The car's or the donor engine? I have to use the newer engine emissions equipment..
Clone TIE Pilot
3,861
2,612
Galaxy far far away
The original equipment won't work with a more modern LS motor, it must be the donor engine's emissions equipment.
skatepirate77
Mar 12, 2010
66
I meant the donor car emissions stuff. Sorry for the confusion. As long as it is present for the visual it will pass visual.
85GPLef41
2,210
159
Colorado
i have to have it present and be functional.. :blam:
79loserbluebu
960
20
Illinois
There is absolutely no way to do this swap for under $3k unless you make most if not all of specialty parts. It all depends on how much fabrication you want to do, how much your budget is, and how much time you've got to get it done.
Oh yeah and how fast you wanna go :mrgreen:
