400 bore times 327 stroke makes 352?? That just about lines up with the book math that says it works out to around 350. Ironic thing here is that I already happen to have a 327 forged crank and it is sitting in that 400 block that I also happen to have . Only thing I am not sure of at this point is whether that crank happens to be the late model large journal or the earlier small journal version that needs inserts behind the bearings to space them correctly.If you do go with the 400, i know where a forged 327 crank is. It is 3.25 stroke. Makes a 352 there or about with +30 over bore.
Using a 350 crank gets you about 377 which was old school NASCAR build, but not used any more. 30 over bore gets you 4.155 which is a lot of meat, but wind that up to 7000, would be fun street car.
