No you cant. The Grand National motor is not the same as na 3.8. While they both share the same heads and block. The GN motor has different pistons, crank , harmonic balancer, flexplate also block would need to be drilled for oil return. An a true GN block at least the good ones would have 109 casting. If your block has a 109 casting then you can build that block into a gn spec bottom end. This block was only in 86-87 Gm cars no other year had the 109. The older turbo 3.8 also had different internals.
