othtim said:
Engine makes approx 400 hp crank, estimated. .........I have still like another 1000 rpm of gearing before I run out of gear. TH350, 2.29 rear end
othtim said:
Even at the end of the 1/4 im probably doing near 200km/h (i always keep accelerating a bit past the traps so I dont accidentaly let off too soon).
Say what?
Unless your car weighs 2600lbs I dont think so.
Inspite of that, you are probably experiencing the limits of the car (hopefully on a track). The fastest ive ever been is 225km/h, and what happened was about 220km/h the pressure under the front of the car overcame the weight of the front of the car. This raised the front end of the car just enough to start acting like a parachute. The feeling was the same "hit the brakes" you described. The car would have continued to accelerate but I had to back off. The steering felt like it was not connected, and the sound of the air rushing by changed (probably increased a couple of decibles).
http://en.wikipedia.org/wiki/Drag_(physics)
If you are so inclined, you can figure out what the top speed of your car should be. You need to calculate the drag co-efficient, and the projected frontal area of your car. There is a formula for the co-efficient. Plug those values in to figure out your Drag Force (sounds like a racing superhero league). All this will allow you to calculate your Power required to overcome that speed. You could rearrange the formula to solve for max speed since power is a "known".
Power will be in units of work over time, which will tell you how much fuel you will need to get the power. All kinds of fun stuff in there like reynold's number too. Make sure your units are the same!
This is why there are online calculators for this sorta stuff
Anyway, at that speed you are probably near what your car is capable of. If you can work out the calculations above, you can also determine what kind fuel your car is getting at those speeds, and whether or not its adequate.
Probably not too many people running their "stock" cars to those sorta speeds.
