Check Engine and Brake Light On
Esotericnem
21
I have a 81 Cutlass and my Check Engine and Brake Light stays on when I start the car, I had a 350 dropped into the car and I notice there is a lot of wires that aren't hooked up because it used to be a 6 cycl, what should I do so the check engine light goes off? As for the brakes, the car stops fine but what should I check so the brake light goes off? (P.S. The emergency brake is unhooked, would that make the brake light turn on?)
78mali350
1,689
5
38
Pratt, KS
sounds like maybe the brake light would be on because of that. my GEN light was on because of a bad alternator maybe that's what your check engine is
pose_442
243
2
Is your 350 hooked up to a computer at all? If the computer has a bad connection (such as a blown check engine light fuse), the light will stay on. This is usually true with a motor swap w/o hooking a computer back up.
More than likely, you just need to pull the instrument cluster out slightly, and pull out the "check engine" light bulb. It's about a 20-30 minute job for the first timer.
Here's a great how-to source on the removal of the cluster. You can do it w/o even taking the speedo cable off the cluster.
http://tech.oldsgmail.com/eint_cluster.php
Good Luck
Chevyman85
594
Bonney Lake, WA
If you did a V6-V8 Swap you more than likely have so many sensors that are unhooked you'll never be able to turn off the Check Engine Light. I completly removed my computer and pulled the bulb. Thats one way of doing it... I was throwing all kinds of codes! :lol:
GP403
Administrator
Site Admin
Moderator
Feb 25, 2005
4,517
4,940
Rolla, MO
pontiacgp said:
I never heard of an 81 having a computer and a check engine light.. :?:
'81 was the first year they started using the ECM setups. Unless you had a diesel :D They made quite a big deal of it in the dealer lit. If only they knew what a PITA it would be! ha!
