EL CAMINO Code 53, where to start to narrow down issue?
schwim
29
2
Coastal VA, US
Hello, friends!
1987 El Camino with 305/200 4r
When driving, it takes about 15 minutes or so of driving but eventually the Service Engine Soon light will illuminate. When bridging port A and B, I got only one code, that being 53.
Repair Pal says it can either be system voltage too high or Digital EGR valve solenoid 1 error. Voltage at the battery is within acceptable limits when I check it and the EGR valve on the intake was replaced along with fuel pump and a rebuilt carb from Mountain Man last week.
How can I narrow this down without aiming a parts gun at it? Where should I start?
Thanks for your time!
78Delta88
1,303
1,096
SW Arizona
First disconnect the battery ground for 10 -15 seconds and see if that clears it. Then on next drive see if it comes back. I think 14.7 to 15.3 or more would spike the high volt measurement. If that is the case you need to find the cause. And even though "new"... It could be you have bad solenoid.
schwim
29
2
Coastal VA, US
Is the EGR valve located on the intake the solenoid in question or is the solenoid located elsewhere? I've never heard of the egr valve being termed a solenoid. Also, repair pal states
Digital EGR valve solenoid 1 error​
On vehicles with three solenoid EGR valves an open or short on the solenoid 1 circuit will set code 53.
Fault Code Description
  • 53 - Digital EGR valve solenoid 1 error
Symptoms
  • EGR solenoid 1 will not function
Common Problems
  • Broken wire to EGR valve
  • Faulty EGR valve
but I don't have a wire going to the EGR valve, I've got a vacuum line. I'll do more Googling.
78Delta88
1,303
1,096
SW Arizona
The solenoid would control the vacuum signal to the EGR. Should be like a little black box with a 2 wire connector and one vac line going in and another vac line going out.
If I remember ... Been a long time... On driver side in front of carburetor.
78Delta88
1,303
1,096
SW Arizona
Something similar to these...
schwim
29
2
Coastal VA, US
Wow, I can't find an actual available source for GM 1997168. If mine's not working, do I just look for used and hope for the best?
ELCAM
1,124
1,270
78Delta88
1,303
1,096
SW Arizona
Try this one...
From another forum going back to 2001 to 2002
78Delta88
1,303
1,096
SW Arizona
Sounds like 87 to 95 was same basic system, but changes in ECM were causing issues.
