When I shift through my gears its too soft. Its like you barely have to touch the lever to change gears. The problem is that it seems to not be engaging in the gear as indicated on the dash. I have looked under the car while somebody goes through the gears and the lever on the transmission is moving as it is supposed to. I have also adjusted going from the column to the bracket.
If I drop it all the way down to L1 I can feel it engage in gear. I move it all the way up to reverse through the gears and its like its not engaging them. As you know it wont let you shift into reverse because the lockout switch or whatever. I press the brake to get into reverse and I feel it engage into reverse. I have engaged gears with the vehicle running. I just shifted through the gears with just the key turned.
