Cutlass Bolt Pattern???
J.Rod22
216
9
Georgia
I have a 88 Cutlass Supreme Classic (rwd) and I am looking into buying some 20inch rims for it and i want to know what is the bolt pattern that will fit
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
5 x 4.75
and I hope your going to upgrade your brakes to improve the braking to stop that heavy rolling mass weight
J.Rod22
216
9
Georgia
and what about the offset of the rims? which is the right offset so they wont stick out
DrRansom442
858
2
St Charles Missouri
isn't there a sticky some place about "fitting" a 20" rim on a Cutlass?
Qdub24
1,796
785
Columbus, GA
+13 Offset should work. 5 x 4.75 or 5 x 120.65 is the bolt pattern.
If that's your car in your sig, it looks a lot like my 85 Cutlass.
DrRansom442
858
2
St Charles Missouri
plus 13"? that's wider than any rim he's fitting. His factory 14" x 6" are likely a 3.5" offset - so an extra 9.5" that's a serious skateboard look you got going on there. :puke:
Qdub24
1,796
785
Columbus, GA
The offset doesn't stand for inches. Most 20"+ wheels are 10" wide. I've got several sets so I know what offset he needs so that his wheels DON'T poke out and so that his center cap will fit on the front wheels. Have you ever owned any wheels over 20"?
You'll get more help with your wheels on www.kingofthestreetgarage.com/forums than you will here. There's a lot of old farts on here who hate on big wheels.
DrRansom442
858
2
St Charles Missouri
Qdub24 said:
The doesn't stand for inches. Most 20"+ wheels are 10" wide. I've got several sets so I know what offset he needs so that his wheels DON'T poke out and so that his center cap will fit on the front wheels. Have you ever owned any wheels over 20"?
Can't say I ever would. But domestic cars you tend to order the wheels in imperial or S.A.E standard sizes. I wouldn't throw the metric system into the mix here.
Qdub24
1,796
785
Columbus, GA
Well that's the way that big wheels come. If you didn't know, then now you do.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
so what do you call younger guys who think big wheels are useless and look ridiculous?....
