Cutting Moog 5660 springs
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
Bought a set of front springs to install. Waiting on control arm bushings before I put them in because I don't want to do the job twice..
Thinking I should cut a quarter coil off the springs, just for sh*ts and giggles. I'm assuming I cut the end without th white paint?
They ends just look more similar than I was expecting.
Supercharged111
4,967
7,782
Colorado Springs, CO
That is correct, you cut the end that isn't flat. Drop should be about double what you cut off the spring. You may even go as far as a half coil, but I'll let the others chime in. I went this route years ago on my Crown Victoria.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
Neither end is what I'd consider flat in comparison to other springs I've installed. Lol.
My car sits higher now with a v8 in it than it did with the v6. I'm not really trying to lower it. I just don't want it sitting higher than factory.
I'm thinking 5660 springs -1/4 coil, .5" taller lower ball joint. And depending on the height I'll enter trim the spring a little more or look into drop spindles.
79 GP 4 speed
448
536
I would go with drop spindles to keep the ride and to keep the steering geometry correct
  • Winner
Doug Chahoy
2,565
2,664
I cut 1/2 a coil off of mine with 1/2 inch upper ball joints and Blazer spindles with 17X8 wheels and 245/45 tires.
JAMCAR223
1,853
5,507
Houston, TX.
I cut a 1/2 coil off mine, but unfortunately it's still a rolling frame with no body , so no pics to compare.
carnutjw
625
1,475
Top image is right after installing 5660's minus 1/2 coil. Bottom image is same springs but with 1/2" taller upper and lower ball joints and a couple of years of driving and obviously a little different angle. Should only be 1/2" difference in ride height, but I know it looks like more. Maybe the 5660's did settle a little or my wife is holding it down a bit in the second photo? The only complaint I have with the 5560's is related to shock absorbers. I had new KYB gas a just on my car and they did not have enough rebound control for my springs. I switched to Ridetech HQ series single adjustables and I'm very pleased with the ride and handling.
  • Informative
Reactions: 4 users
