Dual Feed Line Leak
gbodytoys
506
656
Detroit, MI
I have a leak coming from the fitting on my dual feed line to my Summit carb. It's not the fittings that screw into the carb, but where the fuel hose goes has to attach to a fitting that screws into the dual line hose (I hope that makes sense). Has anyone has an issue with this before that can point me in the right direction? The car started right up.
565bbchevy
9,623
12,730
Michigan
It sounds like the flare is not seating properly or was over tightened maybe try some Teflon tape around it as a temporary fix.
79 USA 1
1,065
2,041
Cheektowaga, New York
Is it leaking from the part you have in your hand? The line looks to be stainless steel correct?
Look at the flare to see if there is a burr left at the end of the flare. An O-Ring pick or scratch awl should remove it. If it is clean, check the taper for cracks. If none are found and it is a stainless line you may have to tighten- loosen-tighten a few times to get the angled faces to mate and seal correctly.
Hope this helps!
Bob S.
gbodytoys
506
656
Detroit, MI
Hope this helps!
Bob S.
Yes it's leaking from the part in my hand. It doesn't seem like the thread, more so the pipe, as you guys said, the flare isn't sealed correctly to the the dual intake inlet. I can't find what the exact part is on summit.
pontiacgp
blank
Mar 31, 2006
29,270
20,418
Kitchener, Ontario
Michael Watts
418
201
That kind of dual inlet has issues, The chrome just doesnt fit right. There are factory type set ups and or AN types that fit better and don`t leak. Or even make your own using brass and or AN type fittings as well.
gbodytoys
506
656
Detroit, MI
This is the part that I think is causing problems
It screws into the dual inlet and allows for the rubber hose to attach. The longer piece moves.
I'm going to back and check that I didn't use the brake booster fitting for the fuel line.
gbodytoys
506
656
Detroit, MI
I went and got another fitting and that solved the problem, only to make gas shoot out of the carb lol.
I tried to adjust the float bowls, but the fuel level just wouldn't go down. It's time to take it to the carb doctor before I flood my engine...again. smh.
