Fuel guage not working correctly
henrynchlt
5
4
I have a 87 Cutlass Salon with the Ralley Guages. I pulled the cluster out just far enough to change bulbs and reinstalled it and now my fuel guage goes past full to completely horizontal as soon as it gets power. I checked the ground on the speedo cable, removed the cluster and checked for breaks on the circuit board and cleaned all contact points and tightened screws behind the guaged after cleaning under them. Still the same? What has caused this just from changing the bulbs. Any help appreciated.
69hurstolds
8,198
17,600
You've got an open in your fuel electrical circuit somewhere.
I can't imagine you messing with the guages and something happening to the sending unit. So that's super unlikely.
jcelk
Dec 10, 2014
91
54
i had a problem with the cluster push in connector not making good contact check for cracks in the dash part that holds the connector i think i was able to reach from behind and push the plug into the cluster
henrynchlt
5
4
I'll check that. Thanks
