How to swap different types of rears into G-bodies
RobM
Nov 2, 2016
66
Ozone Park Kid
I was surfing the web and came across this information. I figured I'd post it
and maybe to someone it could be useful.
http://www.hotrod.com/articles/how-to-swap-ford-rear-into-a-gm-g-body/
Also here's some information I found on bowtie.com web site that could be helpful to someone.
http://www.bowtiepower.com/Gbody_chassis.html
Here's some information from mailburacing.com on different types of rear swaps for G-bodies, written by Todd Geister.
http://www.maliburacing.com/tech_rearend_swaps.html
zdeckich
460
346
Fort Worth, TX
Very cool.
pontiacgp
blank
Mar 31, 2006
29,270
20,399
Kitchener, Ontario
malibu racing is missing a bit of info on the A body 12 bolt and the A body 8.2" 10 bolt which comes in two different widths. Like the 12 bolt the 64 to 67 version is 2.5" wider than the G body rear and you need conversion uppers along with a joint on the rear end side of the lower control arm. I have the UMI conversion uppers and tubular lower with a Roto Joint for my 67 8.2" rear. The 68 to 72 version is 4.5" wider than the G body rear and you'll need the conversion uppers but you can use the stock lowers.
  • Informative
151
190
Las Vegas, Nevada
Here is a video I did about installing an 8.8 in my 83 Malibu Wagon.
Reactions: 5 users
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
151
190
Las Vegas, Nevada
#truth.
However, aside from spring perches there is no cutting and welding with this swap. and If you go with a kit to replace the stock shocks with coilovers there is no welding required.
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
