Ok computer/carb combo gurus (are there any here?):
87 Monte Carlo SS with CCC carb. This is likely going to be a long read, but here goes.
Problem: Missing and bucking under light load. Idle and four barrels wide open is fine, no issues.
First I replaced the plugs, wires, rotor and cap. $150 for no change.
Diagnosis: Feedback carb should be seeing a dwell of 30-35 degrees on the mixture control solenoid once the system is in closed loop mode. Dwell is "stuck" at 45 degrees in both open and closed loop. Higher dwell = lean command (exhaust too rich) and lower dwell = rich command (exhaust too lean).
Repair manual says there can only be three things wrong - engine temp sensor, throttle position sensor or oxygen snesor. ETS and TPS pass all tests and I replaced the O2 sensor with a new Bosch.
At first this didn't change anything at all. Then suddenly everything started working two hours after I replaced the O2 sensor. Everything's good right?
Wrong. It was good for a day and it's back to the missing and bucking. The O2 sensor is responding as it should (100-900mV swings when you choke or vacuum leak the engine) but the mixture control solenoid is back to stuck at 45 degrees.
I've removed and checked the idle air bleed and it's fine. I also set the depth of it.
The car is definitley running lean, the plugs are totally clean and white.
The dilemma: why is the carb going to a full lean command when the O2 sensor is responding correctly (IE: not showing a rich condition)? I even checked the O2 sensor voltage at the computer harness and it's correct and accurate.
I even pulled the power chip and stuck the stocker back in and no change.
Would the MAP sensor have anything to do with this? Even though it isn't listed as a potential problem I am wondering if it could be a factor.
