ls 5.3 swap into my 85 el camino
LS1GN
600
8
Central Florida
galvesm said:
how much power does that 5.3l make might want to go that route because the motors are dirt cheap instead of an ls1
I think one of the magazines had 300+ horsepower with a junkyard 5.3, headers and a 4 barrel.
motorholmes
375
16
Pushing 400 hp with a mild cam and valve springs
LS1GN
600
8
Central Florida
I just figured out what a lot of you all probably already knew: the 4.8 and the 5.3 are the same block, same bore, and same pistons. The only difference is the crank/stroke.
What this means is: 4.8s are dirt cheap (as little as $200 around here) and if you wanted, you cold change the crank (rods?) and do what Motorhomes and I suggested and you're at or beyond 400 horses!!!!!!!
79loserbluebu
960
20
Illinois
Yep you guys are right the cranks are the only difference between 4.8's and 5.3's, which is why sometimes you will see "4.8/5.3" cast into the block where the size designation is.
The rods are different.
IMO if you are going through the trouble of swapping cranks, having the rotating assembly balanced, and then replacing the bolts and bearings, might as well put a 4" stroke in the engine and make it a 5.9L.
To the OP very very nice build. Such a clean car and a clean swap. Is there any way to use a low mount compressor with your mounts?
hamiltonbs
9
Thanks for the coments, no I can't do the low campressor mount because of the motor mount adapter plates, it is right where the facory truck bracket goes. at least this way I can use the factory a/c lines from a cutlass with a 307 and be able to buy new ones from a advance auto store if they ever go bad.
