LT1 Dayco pulley squeal
Baker7888
665
115
Maine
Hey guys. 96 LT1 in my Malibu. I have the AC delete bracket which is just a standoff with a pulley. The pulley was close to the frame so i did some homework and found a smaller Dayco and a belt. Much better. But it started to squeal. I pulled it, popped the dust shields and packed the bearing. The grease liquified pretty quickly, made a mess and started squealing again. I bought a new pulley. Squeals right out of the box. Looking for suggestions here !!
dyrt
41
13
8
Yardville, NJ
Check to make sure the bolts that hold the bracket in place did not back out. The squeal could be the new belt being a little too loose also. Last, buy a brand new pulley, pull it apart immediately and pack it with the thickest heaviest grease you can get and see if you get the same results.
I bought mine used and replaced the pulley on it with a stock size but I also heated up the frame horn and hammered it in for clearance there when I initially installed the motor and the ac pump was in place. I don't get a ton but it was enough to squeeze a belt through.
Edit : is this a real Delco part or one of the dorman repros?
Baker7888
665
115
Maine
Thanks for the response. Bolts are tight.
Do you have a suggestion on grease? Was suprised to see how luquidy this stuff became. Regular red grease gun grease.
Belt is tight, tensioner is almost maxed out. I have a bigger belt as well, same results.
Dayco* not Delco.
Last thought, wondering if i can get a better quality bearing to press in ??
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,702
Spring, Texas
Dayco* not Delco.
Maybe high temp wheel bearing grease?
ELCAM
1,124
1,270
Need pictures, both large and small pulleys front and back and the stand off/bracket.
Part numbers might help too.
Nov 4, 2012
6,029
12,789
Not sure that the pulley is your problem but I stopped using Dayco stuff several years ago. Quality just isn't there. I switched to Gates and haven't looked back.
Baker7888
665
115
Maine
Current pulley (small one) is p/n Dayco 89130
First pulley (large one) came with the bracket. Almost touches frame.
Standoff bracket is p/n Dorman 34209
(I believe this is the one I used)
