Magnetic Transmission Drain Plug
Kiko
300
341
Ottawa, Canada
Instead of overpaying for a magnetic transmission drain plug (3/8" NPT), does anyone see a problem with attaching a strong rare earth magnet to a regular plug? Anyone done that?
Any likelihood that the magnet will be dislodged and damage the transmission? Note: My pan is cast aluminum, hence magnet needs to be mounted on the drain plug.
Thanks in advance for any advice!
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,996
Socialist NY
Just go to the chain stores Advance/Autozone get a 3/8 drain plug they are around 5 buxx
4
Texas82GP
Just-a-worm
Apr 3, 2015
7,993
18,729
Spring, Texas
Andry, I'm in a similar situation with the 4L80E swap in my truck. I bought a deep cast aluminum pan. It has a magnetic drain plug but I deem it insufficient (perhaps wrongly). I'm thinking about gluing the OE 4L80E magnet to the bottom of the pan using super weatherstrip adhesive. The stuff can be used for gaskets so I think it will hold up.
Kiko
300
341
Ottawa, Canada
I'll check if our Canadian outfits have these... It's so much easier to get auto parts down in the States!!
Might not be a bad idea...
Guys, thanks for the replies!!
Andry
TURNA
Jul 24, 2009
10,941
19,996
Socialist NY
Dorman makes them so you shouldn't have a problem.
Kiko
300
341
Ottawa, Canada
Thanks Turna, I'll look into this!
