Making my Regal upper door panels
565bbchevy
9,614
12,683
Michigan
Since my new interior is a shade off from my faded stock interior I am making new upper door panels with extra material that came with my seats, the rears I already made so I could get everything else to this point.
You can see my stock one on top and the new one below and I still haven't decided if I am going to completely black out the door handle or leave some chrome and I happened to a good amount of carbon fiber vinyl just to get an idea.
I started but striping off all of the material after carefully removing the inner felt and lock ferrule and with all the holes left I decided to glue thin cardboard over the top and run it to the top edge of the metal, I found cereal boxes worked really well. lol
From there I glued a layer of felt to give it a smooth base.
Then I laid out a simple design and used 1/4" thick hard foam and after that I glued those on.
And from there I carefully glued on my material and used a 1" roller to get the edges tight so as of right now this is what it looks like until I decide what the final look of the handle will be and I still have to remount the inner felt.
  • Creative
  • Winner
Reactions: 9 users
565bbchevy
9,614
12,683
Michigan
I took a spare handle and sprayed it black to get an idea of how that would look, might just go this route for the handle.
  • Creative
Reactions: 7 users
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Very nicely done!!
Turbo Zach
2,534
5,874
You made that look too easy! Looks good. I am curious as to what you are going to do with the wood grain on the dash?
565bbchevy
9,614
12,683
Michigan
I have already blacked out all of the woodgrain on the dash.
565bbchevy
9,614
12,683
Michigan
So I finished the upper door panels and decided to keep the chrome on the handle and flat black vinyl on the woodgrain, I figured there is enough chrome still in the interior.
I also relocated the power window switches to the lower half of the door, the harness works well in this spot also.
Reactions: 4 users
565bbchevy
9,614
12,683
Michigan
And here it is when I was doing the mock ups deciding what route to go with the handle.
  • Winner
Reactions: 4 users
565bbchevy
9,614
12,683
Michigan
Nice job man :cool:
Thanks, I figure they look a little better than my faded stock ones that were a shade off anyways.
Plus I like having a door speaker up high.
